fxs help!!
I have a 3640 with a NM-2V module. One slot in the module has an FXS card. I have signaling set to loopstart and ring frequency set to 50. When I plug in the phone a "SELFTEST" text comes up and then the phone is blank. The phone has a digital display. It is an Ericsson consono MD110. I am not sure if this phone qualifies has a "standard" phone. Any help will be appreciated.
dump of 'deb vpm signal' command
02:42:23: [2/0/0, FXSLS_OFFHOOK, E_HTSP_PRE_CONN_DISC]
02:42:53: [2/0/0, FXSLS_OFFHOOK, E_HTSP_RELEASE_REQ] fxsls_offhook_disc
02:42:53: htsp_timer_stop
02:42:53: [2/0/0] set signal state = 0xC timestamp = 0
02:42:53: [2/0/0] set signal state = 0x4 timestamp = 750
02:42:53: htsp_timer - 950 msec
02:42:53: [2/0/0, FXSLS_CPC, E_DSP_SIG_0100] htsp_report_onhook_sig
02:42:53: [2/0/0, FXSLS_CPC, E_DSP_SIG_1100] htsp_report_offhook_sig
02:42:54: [2/0/0, FXSLS_CPC, E_HTSP_EVENT_TIMER] fxsls_cpc_timer
02:42:54: htsp_timer - 30000 msec
02:42:54: [2/0/0, FXSLS_WAIT_ONHOOK, E_DSP_SIG_1100]
02:42:54: [2/0/0, FXSLS_WAIT_ONHOOK, E_DSP_SIG_0100] fxsls_waitonhook_onhook
02:42:54: htsp_timer_stop htsp_report_onhook_sig
02:42:54: [2/0/0, FXSLS_ONHOOK, E_DSP_SIG_1100] fxsls_onhook_offhook htsp_setup_
ind
02:42:54: [2/0/0] get_local_station_id calling num=6000 calling name=charles cal
ling time=00/00 00:00
02:42:54: [2/0/0, FXSLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
02:43:04: htsp_pre_connect_disconnect, cdb = 627C3F10 cause = 1C
02:43:04: [2/0/0, FXSLS_OFFHOOK, E_HTSP_PRE_CONN_DISC]
02:43:34: [2/0/0, FXSLS_OFFHOOK, E_HTSP_RELEASE_REQ] fxsls_offhook_disc
02:43:34: htsp_timer_stop
02:43:34: [2/0/0] set signal state = 0xC timestamp = 0
02:43:34: [2/0/0] set signal state = 0x4 timestamp = 750
02:43:34: htsp_timer - 950 msec
02:43:34: [2/0/0, FXSLS_CPC, E_DSP_SIG_0100] htsp_report_onhook_sig
02:43:34: [2/0/0, FXSLS_CPC, E_DSP_SIG_1100] htsp_report_offhook_sig
02:43:35: [2/0/0, FXSLS_CPC, E_HTSP_EVENT_TIMER] fxsls_cpc_timer
02:43:35: htsp_timer - 30000 msec
02:43:35: [2/0/0, FXSLS_WAIT_ONHOOK, E_DSP_SIG_1100]
02:43:35: [2/0/0, FXSLS_WAIT_ONHOOK, E_DSP_SIG_0100] fxsls_waitonhook_onhook
02:43:35: htsp_timer_stop htsp_report_onhook_sig
02:43:35: [2/0/0, FXSLS_ONHOOK, E_DSP_SIG_1100] fxsls_onhook_offhook htsp_setup_
ind
02:43:35: [2/0/0] get_local_station_id calling num=6000 calling name=charles cal
02:43:35: [2/0/0, FXSLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
02:43:45: htsp_pre_connect_disconnect, cdb = 627C3F10 cause = 1C
02:43:45: [2/0/0, FXSLS_OFFHOOK, E_HTSP_PRE_CONN_DISC]
02:44:15: [2/0/0, FXSLS_OFFHOOK, E_HTSP_RELEASE_REQ] fxsls_offhook_disc
02:44:15: htsp_timer_stop
02:44:15: [2/0/0] set signal state = 0xC timestamp = 0
02:44:15: [2/0/0] set signal state = 0x4 timestamp = 750
02:44:15: htsp_timer - 950 msec
02:44:15: [2/0/0, FXSLS_CPC, E_DSP_SIG_0100] htsp_report_onhook_sig
02:44:15: [2/0/0, FXSLS_CPC, E_DSP_SIG_1100] htsp_report_offhook_sig
02:44:16: [2/0/0, FXSLS_CPC, E_HTSP_EVENT_TIMER] fxsls_cpc_timer
02:44:16: htsp_timer - 30000 msec
02:44:16: [2/0/0, FXSLS_WAIT_ONHOOK, E_DSP_SIG_1100]
02:44:16: [2/0/0, FXSLS_WAIT_ONHOOK, E_DSP_SIG_0100] fxsls_waitonhook_onhook
02:44:16: htsp_timer_stop htsp_report_onhook_sig
02:44:16: [2/0/0, FXSLS_ONHOOK, E_DSP_SIG_11
-Charles
Re: fxs help!!
the problem is probably the phone.
-charles
Re: fxs help!!
Try to set Ring Frequency to 25.
Ken
792
