FXS Not passing DTMF
I have a Cisco 1760 with FXS ports in it that connect to a PBX. Everything works fine, but i cannot seem to pass DTMF tones to the PBX.
If a caller calls in and gets the auto attendant, they need to dial 100 for one user, 200 for another and so on.
Can this work with FXS ports?
Dave
Super Bronze
Re: FXS Not passing DTMF
I don't think the FXS port is the problem - you probably just need to set up DTMF relay - do this on the FXS gateway and on any other gateways along the call path...
If you use MGCP you should have a command something like:
mgcp dtmf-relay voip codec all mode cisco
If h323, on the VOIP dial-peers you'll need:
dtmf-relay h245-alphanumeric
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
We are using h323 and our dial-peer looks like this:
dial-peer voice 6101 voip
huntstop
destination-pattern 6045551234
session target ipv4:10.157.0.2
dtmf-relay rtp-nte
fax rate 7200
ip qos dscp cs5 media
no vad
We tried the dtmf-relay h245-alphanumeric and still have the same issue.
When i use dtmf-relay rtp-nte it works from my cell phone (Bell Canada) but not from Rogers or Telus. Any ideas?
Silver
This is not possible with FXS because FXS does not pass DTMF digits. You would need to use either FXO or E&M to integrate with the PBX.
Check this link for more details
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a00800d62d2.shtml
Anup
505
