fxs to fxs how to apply codecs
hi i have implemented a point to point voip solution using fxs cards at both the sides.and its working perfectly.the leased line bandwidth is 128 kbps.how can i apply codecs and minimize the voice packet bandwidth pls check the configuration of both the routers.
sh run
Building configuration...
Current configuration : 1278 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
--More-- !
voice-card 0
username cisco privilege 15 secret xxxx
interface FastEthernet0/0
ip address 192.168.10.5 255.255.255.0
duplex auto
--More-- speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
ip address 128.10.x.x.255.255.252
ip route 192.168.x.x.255.255.0 128.10.10.1
ip http server
control-plane
voice-port 0/0/0
--More-- !
voice-port 0/0/1
dial-peer voice 1 pots
destination-pattern 5577
port 0/0/0
dial-peer voice 2 voip
destination-pattern 5578
session target ipv4:128.x.10.2
dial-peer voice 3 pots
port 0/0/1
dial-peer voice 4 voip
--More-- dial-peer voice 5 voip
destination-pattern 5575
session target ipv4:128.x.10.1
dial-peer voice 6 voip
destination-pattern 5576
line con 0
line aux 0
line vty 0 4
password xxx
login
scheduler allocate 20000 1000
end
config of 2nd router.
sh run
Current configuration : 2413 bytes
version 12.4
hostname OETC-QURM
boot-start-marker
boot system flash c2801-ipvoice-mz.124-6.T2.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
--More-- !
ip domain name yourdomain.com
voice-card 0
username xxx privilege 15 secret xxxx
--More-- interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.1.2 255.255.255.0
speed auto
full-duplex
ip address 192.168.50.2 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.x.x.10.10.2
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
--More-- control-plane
voice-port 0/0/0
voice-port 0/0/1
dial-peer voice 7 pots
port 0/0/0
dial-peer voice 8 voip
session target ipv4:128.10.10.1
dial-peer voice 9 pots
port 0/0/1
--More-- !
dial-peer voice 10 voip
dial-peer voice 11 voip
session target ipv4:128.10.10.2
dial-peer voice 12 voip
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
password ocs
login
transport input telnet
line vty 5 15
privilege level 15
--More-- login local
end
pls post your views, all the replys will be appreciated with proper ratings.
Regds
Binoy
Re: fxs to fxs how to apply codecs
If i am not mistaken. The default setting for VOIP is using codec G.729. No setting required
thanks for your reply.
have u seen the given configuration.G.729 is not configured on this, u mean to say by default cisco router will take G.729 if yes what will be the bandwidth of a voice call.
will it take 64 kbps for a single call.
if it takes 64 k how can i decrese its bandwidth.kindly suggest solution for this.
Regds
Binoy
Without any codec configuration on the dial-peer, G.729 will be used. G.729 is around 16kbps for single call. You can view the call detail by "show call history voice brief".
lee thanks for your reply.
can you give me some pdf's regding this for reference.and i need to do the "show call history voice brief" while calling or after the call from this commands output can i see the codec which is default in this routers.
which all other codecs i can use to save bandwidth. pls give some more details abt this.
Regds
Binoy.
Binoy,
If you want to specify the codec you have to add this command under the voip dial-peer
codec g729r8 bytes 40
g729r8 is the codec
40 is the payload which you can change according to your design
you can find all the commands in
"Cisco IOS Voice Command reference"
Omar
This link points to the document that shows in detail how bandwidth is calculated for different codecs and also explains the terms.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
Hope you find it helpful. Please rate all posts.
HTH,
Sulabh
240
