12-18-2002 03:33 AM - edited 03-12-2019 10:00 PM
1. In a VoIP configuration with multiple remote sites and a gatekeeper, how does the remote site know what are their E164-IDs to send when registring? Does the router assume the "destination-pattern" from all the "dial-peer voice XX pots"? All FXS, FXO, E&M and E1?
2. With just one zone with several gateways, how do i define a prefix to a gateway? Can't use "zone prefix" without "zone local" and i want just one zone.
3. Is there a configuration example of a case study with VoIP, a gatekeeper and several remote sites? The only one i found (the Raleigh/San Jose example) was w/ only one remote and one gatekeeper.
12-26-2002 07:40 AM
Hope you find the answer in one of these many GK docs
12-26-2002 12:43 PM
I saw and read that docs but there's no info on configuring several gateways with one gatekeeper.
12-26-2002 09:00 AM
I have 100+ voip gateways. We run GK with this. If you would like I can email you a sample of what we have. We only have one zone. My email is tcairns@estes-express.com.
Trae
01-03-2003 04:52 AM
Trae, what tools do you use to monitor such an amount of gateways?
For example, whether PRI-s are up, what is ASR ratio, is any destination overloaded, accounting, ...
Nikola
01-03-2003 05:51 AM
Hi.
Has i understood, they don't have any PRIs installed. Only FXS. And that's why the gw, when regstring, send E-164 IDs with the dial-peer POTs they have.
So you know if there's a way to do it when you have E&M, FXO, PRI or BRI?
Telmo
01-04-2003 03:13 AM
Hi Telmo
We have VoIP setup with few Gateways and a Gatekeeper. Calls coming to Gateways are from GK but send directly to our provider. In FXS yes they do use the E-164 for registration with GK but in FXO (connected with PRI) case we have to use the tech-prefix ( its not the dial-peer tech-prefix but used under the config of the Gateway setting). I have done the Gateway and Gatekeeper setting but i am not sure its the optimal setting or not. Sample of my config is here please correct me if i am wrong or if someone have the better experience. help will be appricated. Thanks
gatekeeper
zone local XYZ-GK test.com 123.123.123.123
zone remote ZYX thedomain.com 321.321.321.321 1719
zone prefix XYZ-GK 1231121* gw-priority 10 Isl
zone prefix XYZ-GK 1231131* gw-priority 10 Khi
zone prefix XYZ-GK 1231141* gw-priority 10 Lhr
zone prefix XYZ-GK 1231151* gw-priority 10 Peh
zone prefix XYZ-GK 1231161* gw-priority 10 Qut
zone prefix XYZ-GK 1231171* gw-priority 10 Mlt
zone prefix XYZ-GK 12311* gw-priority 10 Isl
gw-type-prefix 44567#* default-technology
Gateway ( one sample GW config)
interface FastEthernet0
ip address 111.111.111.111 255.255.255.240
h323-gateway voip interface
h323-gateway voip id XYZ-GK ipaddr 123.123.123.123 1718
h323-gateway voip h323-id Isl
h323-gateway voip tech-prefix 44567# ---> this command is used for reliable registration with GK.
