Gateway 2651xm configuration problem
Excuse my limited knowledge but I really need to know how to change the "Type:" from "Unknown" to "National".
Calling Party Number i = 0x0081, '492xxx9xxx69'
Plan:Unknown, Type:Unknown
thanks in advance
Janis
Re: Gateway 2651xm configuration problem
Janis,
You can change the called/calling party number type in Callmanager administration. Go to Device -> Gateway. Find your gateway and find the originating port. You will see Called party IE number type and Calling party IE number type. The default for these is Cisco Callmanager which works well most of the time. If you are outside of the US or are connecting to a PBX, another type may be required. The type can also be changed on a more granular basis (based on called number, etc) by using voice translation rules on the gateway. Take a look at the following link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#type_plan
Hope this helps. If so, please rate the post.
Brandon
Thank you, Brandon.
Fotunately I found it myself on the cisco sites.
The right command to change the TYPE is:
Router(config-if)# isdn map address telephone-number plan isdn type national
Have a nice day, Brandon.
113
