gateway and gatekeepr in one box
can we implement gateway and gatekeeper in one cisco device? If yes, what platforms support it?
Y.
1 ACCEPTED SOLUTION
Blue
Re: gateway and gatekeepr in one box
Yanna, The quick answer is IP Plus with MCM.
Silver
Yes you can have a gateway and gatekeeper on the same box, this is supported on the 26, 36/37 and 7200 series platforms
thanks for your reply,
what ios feaure set must the device run? Do you know where I could find more information in CCO?
Y.
http://www.cisco.com/en/US/partner/support/index.html
Check here for Software advisor. you can find out what feature set you need using this tool.
Blue
94
