Gateway for IP Telephony ????
HI ,
Need to know the basic requirement for designing a router as a gateway to the PSTN. I need only 30 PRI lines ie E1
No analog lines on the router. Can a cisco 1721 router with ip plus software and VWIC-1MFT-E1 support my requirements OR do I need a 1751-V or 1760-V router with the VWIC -1MFT-E1 and the PVDM-256-20HD ???? Confused whether i need the PVDM module ......
The router will be the gateway to the PSTN network for my IP telephony LAN network.
Rgds
Renzil
1 REPLY
Silver
Re: Gateway for IP Telephony ????
!721 is not voice capable, so you are out of luck here !
The PVDM is a small circuit board that contains the DSP's (Digital Signal Processors) - these are used to compress and packetise the voice traffic. You need them to run voice.
To handle a full E1's worth of voice calls with G711 or G729 codec you would need a 1751 or 1760 router with IP Plus software and a PVDM-256-20HD. This particular PVDM has 5 DSP's that support 6 calls per DSP when running a G711 or G729 codec , refer here for more information -
http://www.cisco.com/warp/public/788/products/1750-vic-issues.html
273
