Community Member
Gateway for VoIP?
In an effort to implement VoIP solution at my HOME, I found that I could use either cisco uBR924 cable modem router or 827-4V ADSL. I came to know that in order to call PSTN numbers around the world, I should use a gateway. Here are my questions:
1) Is there any service provider who provides JUST gateway service to accomplish VoIP.
2) Are there any standalone Cisco products that provides a gateway service. If so, does it interoperates with ADSL and Cable modem.
I am looking for a cost effective gateway product to accomplish connectivity to PSTN to cut international calls telephone cost.
Raj
Bronze
Re: Gateway for VoIP?
Most Cisco routers can act as a gateway so it's easy to have a standalone gateway on your network. Your Internet SP should provide gateway services for VoIP. If they don't, you might have to get a new SP. I haven't seen any Gateway only SP's out there. Has anyone else?
Community Member
I just did a google search for sp voip gateways. No luck, Sounds like a great oppertunity for ISPs out there!
Community Member
I work in Netone, who has Gatekeeper(3640) and voice router(AS5300). I think i can help you on this.E-mail me. (Wildrose@netone.gr)
128
