Gateway without T1/E1
I have two separate working environment in my Lab:
1. IP environment(uses SIP Server,soft switch and SIP Phones) and
2.Telephony environment(uses Soft switch, Telephony server and Soft phone)
My Question is;
1. Do I need Gateway to transfer calls between Telephony(Soft Phone) and SIP Phones?
If So, is there a Gateway(without T1/E1)to test my scenerio?
Note: I don't want to waste money buying Gateway with T1/E1 for my above Test.
2.If Gateway is not needed how can I transfer call between Telephony soft phone and SIP phones ?
Thanks in advance
Re: Gateway without T1/E1
Thank You...but my login has no access to view the URL.
How can I get a free access to view the html page or can you please attach as a file.
Thank you.
Again the link specifies that SIP/PRI gateway has connection to PSTN via T1/E1. I don't want T1/E1 connection for my test.
Please explain me in detail.
For eg, If I make a call from soft phone(uses soft PBX), it should terminate at SIP Phone.
The gateway will be lying inbetween these two environment.why do I need T1 line for my test?
103
