Gatreway not registered in GK
Whiy my Gatewayy is not registered in my Gatekeeper...
Wath's wrong??
##################### GATE KEEPER ########################
gk01.pecom.com#sh run
Building configuration...
Current configuration:
version 12.0
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname gk01.pecom.com
ip subnet-zero
ip dvmrp route-limit 20000
interface Ethernet0
ip address 192.168.137.3 255.255.255.224
no ip directed-broadcast
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
router eigrp 100
network 192.168.137.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.137.1
ip route 10.255.255.0 255.255.255.0 54.13.20.39
no ip http server
logging trap debugging
logging 54.13.110.229
gatekeeper
zone local gk01.pecom.com 54.13.20.47
no shutdown
end
########################## GATEWAY ##################################
Current configuration : 1676 bytes
version 12.1
no service single-slot-reload-enable
service password-encryption
no service dhcp
hostname h323-gw
voice-card 1
codec complexity high
ip subnet-zero
no ip finger
call rsvp-sync
voice service voip
h323 call start fast
controller E1 1/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital dtmf dnis
description E1 VoIP
gw-accounting syslog
interface FastEthernet0/0
ip address 54.13.20.44 255.255.0.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id gk01.pecom.com ipaddr 192.168.137.3 1718
h323-gateway voip h323-id h323-gw
h323-gateway voip tech-prefix 000#
interface Serial0/0
no ip address
encapsulation frame-relay
shutdown
clockrate 2000000
frame-relay lmi-type ansi
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clockrate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 54.13.20.33
no ip http server
voice-port 1/0:1
dial-peer cor custom
dial-peer voice 1999 pots
destination-pattern 000#.T
direct-inward-dial
port 1/0:1
prefix 000
dial-peer voice 1000 voip
destination-pattern 1#1...
session target ras
tech-prefix 1#
end
REGARDS.
Re: Gatreway not registered in GK
You should define two zone name and the ip address of the CM in each zone' define gw-type-prefix; total bw and default bw between the zones. Sample
config is listed:
gatekeeper
zone local itsc xx.edu.hk
zone local sce xx.edu.hk
zone subnet itsc 172.16.1.201/32 enable
no zone subnet itsc 0.0.0.0/0 enable
zone subnet sce 172.16.21.201/32 enable
no zone subnet sce 0.0.0.0/0 enable
gw-type-prefix 000#* default-technology
bandwidth total default 3072
bandwidth session default 128
no shut
"Show gatek zone " to verify both CM are register to the Gatekeeper.
Michael.
Hello there !
Well you have not enabled the "gateway" so its probably not even attempting to register. Try this...
Enable "gatway" by entering "gateway" from global config (config t) mode and make sure that you see
the follwoing in your gateway config (sh run):
gateway
It should register, use "sh gateway" or on the GK do "sh gatekeeper end"
Hope this helps.
106
