10-27-2005 09:04 AM - edited 03-13-2019 11:01 AM
Very simple setup. Hunt Pilot DN 4000 -> Hunt List -> Line Group (1 member DN 2508). When I dial 4000 I get fast busy. Route this pattern is checked. What am I missing? thanks. cm4.12.
10-27-2005 09:09 AM
Are your calling search spaces and partitions configured correctly?
What happens when you dial 2508 directly?
Have you tried using Dialed Number Analyzer Tool, what result do you get?
Chris
10-27-2005 09:21 AM
Not using css/partitions
2508 rings when dialed directly
DNA shows HL as the end device.
When I dial Hunt Pilot it takes me to CFNA DN.
I was hoping I'm missing something obvious. Hate to do traces.
10-27-2005 09:27 AM
You can try using the Dialed Number Analyzer in the Call manager it is much more easy and gives you the complete path the call takes
10-27-2005 09:47 AM
It is working now. All I did was change the LG and HL names. I had really long names with spaces. After I changed to short names without spaces it started working. Go figure.
10-27-2005 11:16 AM
You have to Reset the hunt list after creation. Just go to the list and do a reset.
Don
