Get used channels on PRI problem
Hello
I'm having some problems with PRI monitoring.
I'm using cpmDS1ActiveDS0 MIB on a 3800 VoIP gateway with 4 PRI (2x2) (IOS 12.4(4)T1)
1.3.6.1.4.1.9.10.19.1.1.9.1.3.0.0 - I can see PRI 0/0/0 total number of calls
1.3.6.1.4.1.9.10.19.1.1.9.1.3.0.1 - I can see PRI 0/0/1 total number of calls
1.3.6.1.4.1.9.10.19.1.1.9.1.3.1.0 - Error
1.3.6.1.4.1.9.10.19.1.1.9.1.3.1.1 - Error
1.3.6.1.4.1.9.10.19.1.1.9.1.3.0.0.x - Error
1.3.6.1.4.1.9.10.19.1.1.9.1.3.0.1.x - Error
The PRIs that we want to see are 0/1/0 e 0/1/1...... (bad luck!)
Do I need to make some special configuration on the Router?
Silver
Re: Get used channels on PRI problem
Could you upgrade the IOS and see if it still persists?
Hi, can you share with me the solution you developed for this problem? I am having the same issue and can't find the proper OID to use. I can use 1.3.6.1.4.1.9.10.19.1.1.4.0 to see all calls across every DS1 which isn't exactly what I'm looking for.
403
