GSM and error
Trying to install the GSM {1.0.10} I get this message, "Setup Cannot continue because some system files are out of date on your system...etc"
I click OK and then the PC reboots.
I run it again I get the message again.
The box is Win2K SP2
I have installed this successfully on Win2K boxes and XP boxes before - so not exactly sure what I should be watching for :-) Any ideas?
Re: GSM and error
You're trying to install this tool using Terminal Services. Go to the console of the box and install it.
adam
Re: GSM and error
Well, actually no - this is the console of a Win2K workstation :-/
Re: GSM and error
Hm... SP3 solved the problem :-/ Weird - another problem now - but it's comepltely differentso I'll put in a different thread.. :-)
90
