->FXO->FXS-> call transfer not working...
We have cisco2811 with c2800nm-adventerprisek9-mz.124-16 and 1 FXO + 2 FXS ports.
at this moment i use CME B-ACD to auto answering and forward call to internal fxs port.
problem - this call, terminated to fxs, cann't be transferred by using flash button on analog phone(to transfer call from fxs to fxs port i use app-h450-transfer.2.0.0.9.tcl)
Can somebody tall me WHAT to use to make transfer feature working??
my config in attachment
Hall of Fame Super Gold
Re: ->FXO->FXS-> call transfer not working...
do you have the documentation for app-h450-transfer ?
I think the service is meant to be configure on incoming dial-peer ?
Another thing you can try, is "SCCP feature mode for FXs port". That would let you have the analog phones with feafures like an IP phone:
http://cisco.com/en/US/products/ps6706/products_feature_guide09186a00806cab75.html
Configuring Feature Mode for SCCP Analog Phones
This task configures feature mode for SCCP analog phones on the voice gateway and enables SCCP analog phones to invoke features using feature access codes after hook flash.
Prerequisites
You must first configure full consultation transfer on Cisco CallManager using the transfer-system full-consult command in order for feature mode to work on the voice gateway.
SUMMARY STEPS
1. enable
2. configure terminal
3. stcapp call-control mode feature
my IOS says that didn't know "stcapp" command....
It requires 12.4XC or later, you have 12.4 mainline.
we currently using c2800nm-adventerprisek9-mz.124-16.bin,
this ios didn't work with stcapp too?
It does not, as I said before it requires 12.4XC or later, you have 12.4 mainline.
will try use app-h450-transfer on incoming dp.
All fixed with:
B-acd tcl script to serv incoming PSTN calls, sccp + e-phones binded to all fxs ports.
As a result - welcom pprompt + transfer to operator + moh + all standart features at internal calls.
Thanks for all for help!
A houp my 2 week sex with cisco wil be helpful for somebody...
254
