H.323 gatewat dropping calls inbound from PSTN
We installed a 3640 and connected it to a PRI. It is our H.323 gateway to the PSTN. Outbound, we have no problems. Inbound, 50% of the times the calls do not go through. i have attached the config and the debug, any advice would be appreciated.
controller T1 0/0
framing esf
crc-threshold 320
linecode b8zs
interface Serial0/0:23
no ip address
no logging event link-status
isdn switch-type primary-5ess
isdn incoming-voice voice
no cdp enable
pri-group timeslots 1-24
dial-peer voice 1 pots
destination-pattern .T
direct-inward-dial
port 0/0:23
forward-digits all
dial-peer voice 3 pots
destination-pattern 0026
port 0/1:23
forward-digits all
dial-peer voice 20 voip
destination-pattern ....
session target ipv4:10.5.1.2
dtmf-relay h245-alphanumeric
codec g711ulaw
Debug when the call drops:
= 0x000A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '6097810964'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '3003'
Plan:Unknown, Type:Unknown
00:08:13: ISDN Se0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8272
Channel ID i = 0xA98381
Exclusive, Channel 1
00:08:13: ISDN Se0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x800A
00:08:13: ISDN Se0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x800A
Cause i = 0x829C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
00:08:13: ISDN Se0/0:23 Q931: TX -> PROGRESS pd = 8 callref = 0x8272
00:08:16: ISDN Se0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0272
Cause i = 0x8290 - Normal call clearing
00:08:16: ISDN Se0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8272
00:08:16: ISDN Se0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x000A
Cause i = 0x8090 - Normal call clearing
00:08:16: ISDN Se0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0272
00:08:16: ISDN Se0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x800A
00:08:16: ISDN Se0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x000A
00:08:24: ISDN Se0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0273
Re: H.323 gatewat dropping calls inbound from PSTN
Your config is pretty straight forward. It seems after 3 seconds we diconnected the callI would look at the debug voip ccapi inout debugs and the CCM traces to see what is going on?
Your "dial-peer voice 1" and "dial-peer voice 20" appear to be overlapping. I would remove the .... and replace it with 3... Also, I would use your access code (eg 9T) in your config. It just makes for less confusion.
187
