02-14-2002 10:03 PM - edited 03-12-2019 02:27 PM
I have a 7750 Rev 2.1 with spe310's and a MRP200 with MFT-T1 module. I have the mrp configured and can see the PRI channels setting idle. I have also configured all the dial-peers. My problem is that when I configure the gateway in call manager it maintains a status of unknow and I can not route calls out it. I also do not get any of the T1 PRI options such as PRI Protocol type, number of digits to strip, etc.
02-15-2002 11:34 AM
Is the gateway configured for H323? If so, the gateway will stay "status unknown". I believe they are working on MGCP support for PRI - ask TAC about it. With MGCP on the PRI Gateway, you will see "See Endpoints" under status, instead of "unknown" Digit strip should be done at the RouteList>RouteGroup level under Discard Digits (or at the Route Pattern Level if you dont need failover within your RL).
02-19-2002 09:23 PM
That's correct -- an H.323 gateway does not "register" to CallManager like a Skinny or MGCP gateway does, so you will never see a registration status.
Similarly, you can't tell an H.323 gateway what PRI protocol type to use, dial plan information, etc. You need to program the gateway configuration with this info.
03-04-2002 02:53 PM
Thanks everyone, did some additional testing and found that the gateway to CM link was O.K. Problem was with the Telco side of the PRI.
