H323 Gateway Problem
I have a 2620 router with two 2fxo-m1 vics as my H323 gateway. The 2 fxo cards are inserted into the Voice 2V nework module. I have all 4 ports with lines connected. When an incoming call is made into voice-port 1/1/0, it and voice-port 1/0/0 busyout.
Config:
version 12.2
hostname cisco2600
enable secret xxxxx
ip subnet-zero
no ip domain-lookup
call rsvp-sync
interface Loopback0
ip address 172.16.0.1 255.255.255.255
interface FastEthernet0/0
ip address 172.16.15.1 255.255.255.0
no ip mroute-cache
duplex auto
speed auto
h323-gateway voip bind srcaddr 172.16.15.1
ip classless
ip http server
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
connection plar opx 1234
voice-port 1/1/1
dial-peer cor custom
dial-peer voice 10 voip
destination-pattern ....
progress_ind setup enable 3
session target ipv4:172.16.15.6
dial-peer voice 11 pots
destination-pattern 9T
port 1/0/0
line con 0
line aux 0
line vty 0
password terminal
login
line vty 1 4
login
end
Bronze
Re: H323 Gateway Problem
You are receiving 4 digits from your telco? are you using translation patterns to redirect, or are the numbers coded directly on the ip phone?
Geoff
Two of the trunks are being redirected by PLAR because we are not receiving anything from the telco. The other two will receive the normal digits from the telco.
Bronze
it looks like your dial-peer voip is set to receive 4 digits. is that what the telco is sending? you may need to change it to 7 or 10 digit?
Geoff
I do not think it is a dial-peer issue. I may have misled you with the busy out term. It seems that both ports on two different cards become seized. If I take out the port 1/0/0 under dial-peer 11 I do not have the problem.
A few suggestions before getting into understanding your problem...
There is no h323-gateway voip interface command that I see under the fast ethernet interface. Is that a typo when you pasted the configs ??
I understand that dial-peer 11 is used to make outbound calls. Also I am assuming the call manager (or destination voip gateway) ip address to be 172.16.15.6
Now please explain what is happening when you receive an inbound call on voice port 1/1/0 ? When you say 1/0/0 busyouts, do u mean that you are not able to make a call on 1/0/0, when you receive a call on 1/1/0?
Well we need more information, if port 1/1/0 receives a call and port 1/1/1 goes busy then I would suspect cabling (2-wire/4 wire) issue, because of the architecture of the FXO card.
The wire into the router is a 2 wire loopstart trunk...
172
