H323 gateway questions
I have configured H323 gw... and it works...but...
Question number one....
While I call from outside PSTN to H.323 gw...Why I should hear 2 ringback signals before I hear dial tone ..if I have no connection plar. And I can be connected to some internal number if I have connection plar configured.
Can I change it?
P.S. Call from analog phone (fxs port in the same router/gw as fxo) have no this 2 additional ringbacks...
Question number two....
I can call from analog phone to IP phones... but...when I trying to call CTI numbers I cannot do it.... And when call is forwarded to voicemail... it fail...(like somebody off-hook and then on-hook)....
I can call from IP phones voicemail...it works...
Calling space it not issue too...
What is it?
Can anybody help?
Thanks in advance...
Re: H323 gateway questions
Hi, regarding your secound question it looks like you have a CODEC proplem, you sould check the codec configuration on the gateway.
You absolutely right.... I already figured out....
Default codec was g729....For all CTI ports it should be g711...
106
