TFi
Community Member
h323-voice-quality : IOS 12.2(11)T2
We changed IOS version on Cisco 5350 from 12.2(2)xb5 to 12.2(11)T2.
Now we see, that value of 'h323-voice-quality' of calls is greater, than earlier (value 37 instead of 10). What does it mean, that quality of service is really worse, than earlier or ...?
Also command 'sh call h v b' print uncomfortable report (It was better)
1 REPLY
Silver
Re: h323-voice-quality : IOS 12.2(11)T2
My search for the bugs for cisco IOS version 12.2(11)T2 on voice quality yeilded the following results.
http://www.cisco.com/cgi-bin/Support/Bugtool/bugnav2.pl?swver1=&fset1=&severity1=&resultsperpage1=&target1=&train1=&swver=12.2&target=11&train=T2&mdf_label=Cisco+IOS+Releases&swver2=1010&target2=1294&train2=2261&fset=%3F&keyw=voice+quality&operator=a...
Many of the bugs like CSCds74456 in the search results report poor voice quality with cisco IOS version 12.2(11)T2.
The Cisco IOS version 12.2(11)T2 is not a stable version.It is an early deployment release. I would suggest you to go in for a reliable and stable version which is a GD(General Deployment)
You can get one from the software center by selecting the feature set you require. The link to the software center for the major release 12.2 is
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?majorRel=12.2
Hope this helps.
127
