Hairpinning E1 ports - Layer 3 issue
Hi all,
I have a typical situation where I have to hairpin two E1 ports.
I have a call coming in as IP. I have to route it to a PSTN and back in as PSTN. When it comes back in as PSTN, I can play an IVR on that leg.
I used an E1 crossover cable and got the layer 1 and 2 working properly.
When the call is made, I get the following error
.Mar 24 14:31:23.530: ISDN Se7/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0017
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x00, 0x80, '12345678'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '08451930280'
.Mar 24 14:31:23.538: ISDN Se7/2:15 Q931: RX <- SETUP pd = 8 callref = 0x0017
Standard = CCITT
.Mar 24 14:31:23.538: ISDN Se7/2:15 **ERROR**: call_incoming: Received a call id 0x321 with a bad bearercap from 12345678 on b channel 1
.Mar 24 14:31:23.542: ISDN Se7/2:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8017
Cause i = 0x80D8 - Incompatible destination
.Mar 24 14:31:23.546: ISDN Se7/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8017
.Mar 24 14:31:23.546: ISDN Se7/1:15 **ERROR**: call_cleared: VOICE ERROR: NULL VDEV Common(0xFC): bchan -1, call id 0x801E
I have seup the bearer cap to speech on both the ports. Can someone tell me why this is happening and how to resolve this issue.
Kiran
1 REPLY
Silver
Re: Hairpinning E1 ports - Layer 3 issue
This error might be because 0x80D8 is an Incompatible destination. It could also be generated when a a data call was made to voice number, or a voice call is made to a number that only supports data. Make sure that the dialed number is correct. If the error still persists it could be an issue with the telco switch configuration. You could also take a look at this document which explains the cause codes.
http://www.cisco.com/warp/public/129/isdn_disc_code.html
214
