Hammer Call Analyzer?
cobbc
Has anyone tried this product out? Are their similar Call Analyzers out that are cheaper?
Chris Deren
I used it on a huge IVR/ACD implementaion, not with Cisco though. It is a great tool, but like you said very expensive. I loved the graphical scripting with Hammer CallMaster, made designing complex test scripts a breeze. I also used RADCOM, which was OK, on the version I used if you needed to customize scripts TCL scripting was used.
http://www.radcom.com/Products.aspx?BoneId=660&ObjId=-1&=&=&=&staticName1=&staticName2=
Hope this helps
Chris
