Has anyone successfully installed a 6624 FXS Blade in a Catalyst 6k
I am having trouble installing the 24 port fxs blades in a catalyst 6k chassis and getting them to work register with call manager.
Has anyone got this to work with in a Catalyst 6009 chassis with a layer 2 only, version 1 supervisor?
I have tried 3 different fxs blades (all with the same hardware & firmware levels) and 3 different chassis in two different call manager installations, with no success.
The fxs blades do not broadcast for an IP address from a DHCP server nor if manually configured, attempt to contact the tftp to start to download the config and load files.
1 REPLY
Re: Has anyone successfully installed a 6624 FXS Blade in a Cata
Yes, this has been done successfully by many people in the field.
Can you tell me which version of CatOS you are running on the supervisor?
112
