have urgent problem for dial-peer application..
I have two dial-peer command at my AS5300.dial-peer
voice 886 pots
destination-pattern 02........
port 0:D
dial-peer voice 8861 pots
port 2:D
AS5300 use two PRI to connect my Co PRI circuit.
I can using Cisco 1750 dial to AS5300 calling PSTN by PRI circuit.
I want check my calling number to choose my AS5300 PRI circuit.
what can I do command at my AS5300.
  • Other Collaboration Voice and Video Subjects
Re: have urgent problem for dial-peer application..
I think, one way to implement it is with the command preference. Ie:
dial-peer voice 886 pots
preference 2
port 0:D
preference 1
port 2:D
dial-peer voice 1886 pots
preference 1
destination-pattern 02034.....
port 0:D
dial-peer voice 2861 pots
preference 2
port 2:D
thanks your reply,
but ...
I want to check my called-id,to choice my AS5300 dial-peer voice pots,so can't to use preference, just determine my called id.
port 0:D
port 2:D
90
