07-11-2003 12:46 PM - edited 03-13-2019 12:41 AM
Hello..
If I have a NM-HDV-1T1-24 module on a 2650 router that has 2 PVDM-12s, can I add an addtional 3 PVDM-12s to this module and use those strictly for conference calling?
Solved! Go to Solution.
07-12-2003 08:04 PM
When you create the pri-group, the dsp's needed to service all of the channels will be automatically allocated, this is 2 PVDM's (6 DSP's).
Here is a link that touches on dspfarm DSP usage:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080108fe6.shtml
See the section "Planning for the Number of DSPs Installed"
07-11-2003 12:54 PM
Yes, this will work fine.
07-12-2003 07:30 PM
What are the restrictions on how they have to be divided up? There would have to be enough for the PSTN gateway access, so how many would that leave me for conferencing? Assume all calls on the are G.711.
Colin
07-12-2003 08:04 PM
