Community Member
Help configuring CUBE
I apologize if at some point I don't use the correct terminology. I have just received a CUBE but I am not sure where to start. Here is how it will be connected:
outsideCube ----metroE link ---- myCube --- myFirewall ---myinside network
I would like to know how to configure the following:
1. Cube itself. What do I need to configure so I can neighbor it with the other one?
2. I need to enable the gateway feature.
3. I have CCM 4.1, should I register it with the CUBE or Gatekeeper? How?
4. Dial-peer and Dial-plan
I really need some help in order for me to get this done as soon as possible.Thank you very much.
1 REPLY
Re: Help configuring CUBE
This is all pretty heavily dependent on the protocols you're using.
Here's a link to a good CUBE configuration guide using a SIP trunk and CUCM:
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
-nick
402
