Help, Gatekeeper and ATA Registration Problem
I have a registration problem with a gatekeeper IOS and ATA's 186 H323 Signaling.
When lost a wan connection the problem it happens, when the communication is ok the ATA not is registered in gatekeeper
I check the IP UDP and TCP connection to the ATA LAN to the gatekeeper interface an is ok, the ras packeets and messages are received to the gatekeeper
In debug ras indicate that the paquets are received
This is the configuration and debug ras output
gatekeeper
zone local gk.aeromexpress.com.mx aeromexpress.com.mx
zone prefix gk.aeromexpress.com.mx 111*
zone prefix gk.aeromexpress.com.mx 111* gw-default-priority 10
accounting username xxx
gw-type-prefix 111* default-technology gw ipaddr 172.25.18.53 1720
bandwidth total default 720
bandwidth session default 64
bandwidth session zone gk.aeromexpress.com.mx 768
bandwidth remote 720
bandwidth check-destination
no shutdown
DEBUG "THE PROBLEM IN THIS OUTPUT IS WHIT IP 172.25.142.3"
1 REPLY
Silver
Re: Help, Gatekeeper and ATA Registration Problem
For authenticating using login and password you need a radius server. On the gatekeper you need the security token required-for command. Here is a link that explains it
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t1/h323v2p2.htm#xtocid255056
183
