Help, Gatekeeper and ATA Registration Problem
I have a registration problem with a gatekeeper IOS and ATA's 186 H323 Signaling.
When lost a wan connection the problem it happens, when the communication is ok the ATA not is registered in gatekeeper
I check the IP UDP and TCP connection to the ATA LAN to the gatekeeper interface an is ok, the ras packeets and messages are received to the gatekeeper
In debug ras indicate that the paquets are received
This is the configuration and debug ras output
gatekeeper
zone local gk.aeromexpress.com.mx aeromexpress.com.mx
zone prefix gk.aeromexpress.com.mx 111*
zone prefix gk.aeromexpress.com.mx 111* gw-default-priority 10
accounting username xxx
gw-type-prefix 111* default-technology gw ipaddr 172.25.18.53 1720
bandwidth total default 720
bandwidth session default 64
bandwidth session zone gk.aeromexpress.com.mx 768
bandwidth remote 720
bandwidth check-destination
no shutdown
DEBUG "THE PROBLEM IN THIS OUTPUT IS WHIT IP 172.25.142.3"
Green
Re: Help, Gatekeeper and ATA Registration Problem
A default configuration for local zone does not allow the H.323 terminals to put calls through directly to the destination. All terminals need to place calls through an H.323 proxy. As the Cisco ATA 186 is a terminal, it does not place a call to the default gatekeeper configuration.
http://www.cisco.com/warp/public/788/voip/ata186_no_call_gk.html
//G
gogasca
I don't understand if it is the case.
in the normal operation all ATA's work's and they appear registered in gatekeeper, but when exist a lost WAN and when the connection again is operating, the ATA not is registred reason why calls cannot be made or be received
117
