Help needed on E1 PRI with DID
I have a as5350 router configured with DID for the E1 line witch connects me to the telco.
first of all I see isdn "incoming-voice voice" every where in cisco but there is only modem/data on the CLI of the router, which one is correct. secondly,
outbound connections work but with a number that is not defined in the the local network.(DID is not working as it should be), inbound connections from the PSTN does not work at all. heres the config
controller E1 3/0
pri-group timeslots 1-31
interface Serial3/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice modem
no cdp enable
voice-port 3/0:D
dial-peer voice 10 pots
incoming called-number 1234....
direct-inward-dial
dial-peer voice 100 voip
destination-pattern 1234....
session target ipv4:10.10.10.10
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 200 pots
destination-pattern 9T
port 3/0:D
here is show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial3/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 57
ISDN Serial3/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 0
the only error i get inbound is -
30064771072d12884901888h: ISDN Se3/0:15 **ERROR**: call_incoming: call id 0x29 c
all treated as DOV
thanks
Hall of Fame Super Silver
Re: Help needed on E1 PRI with DID
First in order to process calls on this E1-PRI make sure you change the "isdn incoming-voice modem" command to "isdn incoming-voice voice" under the serial interface.
Also, change the
port 3/0:D
to
port 3/0:15
Change this dial-peer:
direct-inward-dial
to
direct-inward-dial
port 3/0:15
How many digits is telco sending to you? (you can use debug isdn q931 to figure it out)
Your incoming dial-peer will only match DID calls that are 7 digits and begin with 1234.
HTH, please rate all posts!
Chris
Thank you for your repy,
actually one of the things I was puzzled with was the command "isdn incoming-voice voice" command witch does not exist. the only commands available are data and modem. (the as5350 has an IOS of c5350-is-mz.123-11.T11 with a 4 port e1 pri module and two np-60 modules.). Same goes to the dial-peer command it only accepts "d or D" as it states in the CLI.
The telco is sending me 8 digits.
What do you think?
thanks in advance
mahdi
I have checked this again with no luck.
Can any one help me on this?
Your configuration look OK. On AS5350 there is no isdn incoming-voice voice command. Instead you should use incoming-voice modem, which you already have done. And add compand-type and cptone to voice-port.So potential problem could be with number translation. What you should try is to connect a SIP phone and make dial-peer voice to that phone and with appropriate translation test DID.
190
