Community Member
Help on RM-CM Subsystem
I had a big problem after a server restart.
The RM-CM Subsystem remain in OUT OF SERVICE state and into the mivr logs it says:
"com.cisco.wfapi.subsystem.WFSubsystemException: Unable to load CM workflow".
Just tried to refresh scripts and applications and also setup again the ICD resource groups and CSQ, but nothing to do.
Can anyone help me?
Daniele
2 ACCEPTED SOLUTIONS
Gold
Re: Help on RM-CM Subsystem
Make sure somebody hasn't been "cleaning up unused scripts" in C:\Program Files\wfavvid on the IPCC Express server. You should have a workflow named 'cm.aef' in there from the default install. If it's missing, you have problems. You can reinstall IPCC Express or get a copy of cm.aef from a friend with the same version of IPCC Express.
Bronze
Check if the workflow scripts CM.aef and RM.aef are presented under C:\Program Files\wfavvid folder and these scripts are needed for RMCM
subsystem to be in service. If scripts are deleted/missing, restore those files back to bring the RMCM subsystem to IN-SERVICE
Community Member
Make sure that the RM Users password has not changed and the right devices are assigned.
Gold
Bronze
Community Member
Hi all,
yes, this was the cause. The customer's system admin deleted all the unused script few days ago (cm, icd, aa etc). To resolve I did a repository initialization, all the applications were reloaded and then an engine restart.
Now it works again.
Thanks a lot to all
Daniele
163
