08-21-2002 09:15 AM - edited 03-12-2019 08:27 PM
Hi all I have a cisco router 1600 series with the following config.
Can QoS be implemented on the serial 0 under the following configuration for VoIP traffic?? (IOS 11.3) If it is possible which one could be implemented LLQ or IP RTP??
Thanks in advance for your help!!!
Current configuration:
version 11.3
service udp-small-servers
service tcp-small-servers
hostname
enable secret
enable password
ip subnet-zero
interface Ethernet0
ip address 200.249.63.33 255.255.255.252
interface Serial0
ip address 200.249.50.66 255.255.255.252
keepalive 180
bridge-group 1
interface Serial1
ip address 172.16.254.1 255.255.255.0
keepalive 180
bridge-group 1
router rip
network 172.16.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 172.16.0.0 255.255.0.0 Serial1
ip route 172.16.0.0 255.255.0.0 172.16.20.5
bridge crb
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
password
login
end
08-22-2002 08:16 AM
I don't know if you can do it on 11.3 (will have to look it up) but doing LLQ on a 1600 is supported per the following link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t7/pqcbwfq.htm
08-23-2002 07:07 AM
Ok Thanks a lot for the information!!!
Regards!!
Felix
