Community Member
Help, plz, to setup Mind IPhonex with AS5350 !
Hi ALL !!!
We have MIND iPhonex 3.10.042.4
Real-time server in main window display that
gateway AS5350 connected, but over minute disconnected.
And in Status bar: Failed to parsed UDP message from 1.1.1.3 at (time)
My config is following below:
aaa group server radius gr1
server 1.1.1.1 auth-port 1645 acct-port 1646
aaa group server radius gr2
server 1.1.1.2 auth-port 1645 acct-port 1646
aaa group server radius gr3
server 1.1.1.3 auth-port 1645 acct-port 1646
aaa authentication username-prompt Login:
aaa authentication login default local
aaa authentication login h323 group gr3
aaa authorization exec h323 group gr3
aaa accounting network h323 start-stop group gr3
aaa accounting connection h323 start-stop broadcast group gr1 group gr2
group gr3
gw-accounting h323
gw-accounting h323 vsa
gw-accounting voip
radius-server host 1.1.1.1 auth-port 1645 acct-port 1646
radius-server host 1.1.1.2 auth-port 1645 acct-port 1646
radius-server host 1.1.1.3 auth-port 1645 acct-port 1646
radius-server retransmit 3
radius-server key 7 070C285F4D06485744
radius-server vsa send accounting
radius-server vsa send authentication
Thanks to ALL!
1 REPLY
Re: Help, plz, to setup Mind IPhonex with AS5350 !
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
108
