Community Member
HELP! Quick Transfer
I am trying to setup a quick transfer. I have a subscriber mailbox using the open greeting call handler. I am able to make quick transfers by putting the extension and #2. BUT, it is only working for a select number of users. It seems like it is working for the users that I have hand entered into unity but will not work for the people I imported.<br><br>
Anonymous
N/A
Re: HELP! Quick Transfer
do those folks you imported have transfers disabled by any chance? #2 over rides the transfer but if no transfer is active it'll probably skip the greeting with the # and then try and action the "2" and you'll end up in some weird conversation location...
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
Community Member
Actually after testing this a little further the #2 works but I am still wondering why the transfer of calls so it rings the desk doesnt work. Thank you for your response
Anonymous
N/A
What does it show under the page for transfer: transfer to the extension, or send to their greeting?
Steve Olivier
Software Engineer
Cisco Systems
Community Member
It seems that the problem is in the call manager we are still investigating
151
