m
Help understanding call translation-rule
translation-rule 2
rule 0 ^0.% 0
rule 1 ^1.% 001
rule 2 ^2.% 002
rule 3 ^3.% 003
rule 4 ^4.% 004
rule 5 ^5.% 005
rule 6 ^6.% 006
rule 7 ^7.% 007
rule 8 ^8.% 008
rule 9 ^9.% 009
Re: Help understanding call translation-rule
rule 2 says, any input number starting with 2 (say 2142372849) if it goes through the translation rule will replace the first digit with 001.
So 2142372849 will appear as 001-142372849.
you can test this using,
test translation-rule 2 2142372849.
Sankar
PS: please remember to rate posts~!
m
Thanks.
any input number starting with 2 (say 2142372849) if it goes through the translation rule will replace the first digit with 001? not 002?
Thats what i meant...hehe typo..
m
Thanks. How about
rule 0 ^0.% 0
Silver
With rule 0, you are removing the first 0 and adding a 0 back. In effect, no translation take place with this rule.
Anup
m
Thanks, our carrier require 10 digits for outgoing calls. I checked the CCM trace
CCM||PretransformCallingPartyNumber=48333
|DialingPartition=PT-abc-STD
|DialingPattern=0.0[23879]XXXXXXXX
|DialingRoutePatternRegularExpression=(0)(0[237-9]XXXXXXXX)
|DialingWhere=
|PatternType=Enterprise
|PotentialMatches=NoPotentialMatchesExist
|DialingSdlProcessId=(0,0,0)
|PretransformDigitString=00882226847
|PretransformTagsList=ACCESS-CODE:SUBSCRIBER
|PretransformPositionalMatchList=0:0882226847
|CollectedDigits=00882226847
|UnconsumedDigits=
Does it mean CCM send 11 digits to the voice gateway?
and no translation take place if the first digit is 0
Many thanks
Yep..straight passthrough...no change in digits...when u dial a number starting with 0.
PS: please remember to rate all posts!
m
Help, pls
Yep, thats correct.
SITE1-R1#test translation-rule 1 00882226847
The replaced number: 00882226847
May be you can discard the 0 at the friend at the CM itself. of change the translation rule at the gateway.
m
How to discard the 0 at the CM?
at the translation pattern
Route Pattern* 0.0[23879]XXXXXXXX
Called Party Transform Mask 0[23879]XXXXXXXX
Or change the translation rule at the gateway
translation-rule 2
rule 0 ^0. 0
Is it correct?
Set discard digits to pre dot.
m
Thanks, but how to achieve it on the voice gateway. because we got 40 route patterns on the CCM
m
The dial-peer configuration
dial-peer voice 100 pots
destination-pattern 0T
incoming called-number.
direct-inward-dial
port 0/2/0:15
225
