HELP !!!! VOIP Configration required.
I need configuration for a VOIP system.
I want to start a very small Calling Card system.
What Kind of Hardware???
What kind of software???
Re: HELP !!!! VOIP Configration required.
First, you need help. Ask your local cisco salesperson to recommend a voice specialized partner that you can pay to build this solution for you.
You'll need a voice gateway with a AAA server for authenticating and billing. You will need a billing solution such as MindCTI or ISI. You will need to then peer with an LD carrier to hand off the calls.
Or, did you want to build a worldwide voice network as well? JJ.
Silver
This link will probably give you a good start on concepts and requirement:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fvvfax_c/vvfdebit.htm
86
