Help with TCL scripting.
Can these applications be invoked on a voip incoming leg? I tried using a simple test script and it seems it wouldn't invoke it, (I tried the same digits on a pots incoming call and it worked fine)
Re: Help with TCL scripting.
Can you give more details on what you are trying to do? I think the answer is yes.
I am trying to use an application (tcl) to answer on the voip incoming leg of a call. I am using the test script cisco has that gives dialtone when answered and via a pots dial-peer and a pots incoming call it works fine, but a call coming in on voip destined for pots doesn't work on the dial peer.
so dial-peer
dial-peer voice 9000 voip
application tcltest
incoming called-number 9000
will answer an incoming call from the T1 and give dial tone, but if a call from voip comes in with the same digits it won't answer and give dialtone.
98
