Hidden outgoing call for specific caller CCM4.1 specific code
Hello Everybody,
Callmanager 4.1 and pstn gateway as5350 (no mgcp).
I have 3 numbers series (for ip phone) 10XX, 11XX and 20XX. Actually to outgoing call, everybody press 0 and the outgoing number. I would like make a rule for 10XX and 11XX to add for the outgoing number a "code" between the 0 and the number.
For example :
Actually
1000 make a outgoig call for number 12345 : user press 012345. On the gateway pstn number dial was 12345
For 11XX and 20xx it's similar.
But Now, i would like that's :
1000 make a outgoig call for number 12345 : user press 012345. On the gateway pstn number dial was 88812345
For 11XX, make a outgoig call for number 12345 : user press 012345. On the gateway pstn number dial was 88812345
And for 20xx no changing, make a outgoig call for number 12345 : user press 012345. On the gateway pstn number dial was 12345.
*888 are a specific code with the operator.
I don't the best way, on the callmanager, on the gateway? I don't know how to do that?
Thanks for your help.
fab
1 REPLY
Re: Hidden outgoing call for specific caller CCM4.1 specific cod
You can use the translational-rule to change the calling party to null when before sending the call outbound.
138
作成コンテンツを作成するには してください
