HIT ZERO FOR OPERATOR
If I never assign an actual line appearence/extension as "0", can I use the "translation pattern" feature to convert say someone hitting "0" to "100" which is my current operator station? I have tried it but it doesn't appear to work.
Thoughts?
Re: HIT ZERO FOR OPERATOR
Yes, thats exactly what you do, we use it. How have you set it up? The only thing I could see that would stop it working is if you've not got your Calling Search Space and partitions set-up right.
All you should need to do is create a translation pattern named 0 and the called party translation to 100 and select the route option, if you are using partitions make sure that whichever partition you put it in exists in your users calling search space.
Try a CTI route point with call foward all pointing to 100.
jwise@wavenet.cc
Just to avoid confusion the actual field under the translation pattern config sheet is "Called Party Transform Mask"
You would simply put the extension you would like 0 to translate to in this case. Ex. 100 for the receptionist.
Cheers
108
