we have unity 2.46 UM installation integrating with call manager 3.0 When we ring an number and we get the customers greeting, after the greeting we get the Unity to option leave a message or hold for more options. If we hold we dont actually get more options, we do get the send message / delete message options but nothing else. can somebody please advise.<br>thanks in advance<br><br>Virundi.<br><br>
Check the "messages" page in the SA for your subscribers. There are a couple options on there that affect what callers can do after they record their message. They can edit it (i.e. add to it, rerecord it) or they can mark it urgent if allowed or, of course, they can opt not to send it at all.
Yes, we ar getting the options you have stated, however what the message actually says is you can record your messages after the tone OR wait for more options - what are the more options, please advise.
IntroductionCUCM Routing RulesDial String implementation PolicyCUCM Routing LogicSIP URI Call Routing Analysis+++ Case Study: 1 ++++++ Case Study: 2 +++Conclusion
Introduction
Over the last few months, I have had the privilege of working on SI...
view more
Hi All,
Are you getting this error “Installer User Interface Mode Not Supported. The installer cannot run in this UI mode. To specify the interface mode, use the -i command-line option, followed by the UI mode identifier. The value UI mode identifiers...
view more
