Home lab setup help
I have a callmanager 4.1 lab at my house with 4 IP phones. I'm trying to integrate it with my home phone (Packet8 IP phone) so when I dial 9 on the IP phone I get an outside line, and I can actually place calls. Also, all incoming calls will go to a certain phone in the house. My gateway is a 2621 running h323 with 2 FXO ports. The config is pasted below. I believe the only way I can do this is to have a PLAR set up on the router. ANy help in this endeavor would be greatly appreciated.
Mitch
Current configuration : 2784 bytes
version 12.3
service password-encryption
hostname 2621-Gateway
boot-start-marker
boot system flash c2600-is3x-mz.123-15a.bin
boot-end-marker
enable password
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
voice class h323 15
h225 timeout setup 5
interface FastEthernet0/0
description Outside Interface
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 172.16.100.1 255.255.255.0
ip helper-address 172.16.200.5
ip helper-address 10.200.1.15
ip nat inside
no snmp trap link-status
interface FastEthernet0/1.5
encapsulation dot1Q 5
ip address 172.16.200.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.71
encapsulation dot1Q 71
ip address 172.20.71.253 255.255.255.0
ip nat pool mynat 65.191.000.001 65.191.000.001 prefix-length 21
ip nat inside source list 101 pool mynat overload
ip nat inside source static udp 172.16.200.15 53 65.191.000.001 53 extendable
ip nat inside source static tcp 172.16.200.15 80 65.191.000.001 80 extendable
ip nat inside source static tcp 172.16.200.15 25 65.191.000.001 25 extendable
ip nat inside source static tcp 172.16.200.15 143 65.191.000.001 143 extendable
ip nat inside source static udp 172.16.200.15 143 65.191.000.001 143 extendable
ip nat inside source static tcp 172.16.200.15 110 65.191.000.001 110 extendable
ip nat inside source static tcp 172.16.200.15 53 65.191.000.001 53 extendable
ip http server
ip classless
ip route 10.1.1.0 255.255.255.0 172.16.100.7
ip route 10.200.40.0 255.255.255.0 172.20.71.254
ip route 10.200.150.0 255.255.255.0 172.20.71.254
ip route 172.20.65.0 255.255.255.0 172.20.71.254
ip route 172.20.72.0 255.255.255.0 172.20.71.254
access-list 1 permit 172.16.100.0 0.0.0.255
access-list 1 permit 172.16.200.0 0.0.0.255
access-list 101 permit ip 172.16.100.0 0.0.0.255 any
access-list 101 permit ip 172.16.200.0 0.0.0.255 any
voice-port 1/0/0
ring number 4
connection plar 29992
voice-port 1/0/1
dial-peer cor custom
dial-peer voice 1 pots
incoming called-number .
destination-pattern 9T
direct-inward-dial
port 1/0/0
dial-peer voice 100 voip
incoming called-number 4570 Should this be the entire phone number?
destination-pattern 2....
session target ipv4:172.16.200.5
dtmf-relay h245-alphanumeric
codec g711ulaw
gatekeeper
shutdown
line con 0
exec-timeout 0 0
password
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
password
logging synchronous
login
end
Re: Home lab setup help
PLAR is the best setup in this case.
If you run IP Plus image, you can enable MGCP and add the gateway as an MGCP gateway in Callmanager. In the attendant DN field, you can specify which phone to ring.
A problem I failed to point out that I'm trying to address is with the placing outgoing/incoming calls. After the 4th ring on an incoming call I get the busy signal. When I dial 9 to get an outside line, i get a different signal, it sort of sounds like a sick dialtone/busy signal mixture.
Thanks in advance.
For dial out, on the route pattern on CM, uncheck the option "provide outside dial tone". Hope that fixes the problem.
For dial in, are you able to pick up the call on the ip phone ? Check CFwd settings on the phone, if its getting forwarded to voice mail, (CFNA). Unless you have a VOicemail server, you will get busy signal.
PS: please remember to rate helpful posts!
I can dial out now. Thank-you so much that is awsome. After I unchecked the option of provide outside dial tone, I had to reboot the router. But then it worked great.
However, if you can help me with the dialing in, after the 4th ring I get a series of beeps (13) then it hangs up. Where do I enter the number for the phone I want it to ring for inbound calls?
In case of H323 gateway and FXO , PLAR is the way to ring a phone. So you configure this on the gateway (as you have already done). Check your IP Phone whose extension is 29992, if CFNA and CFB are forwarded to any number (which is either voicemail or an external number). If a voicemail server is not available in your setup, it will give a fast busy.
Thanks so much for all your help. Now the phone rings after I get the busy signal on the dialing phone (my cell phone), I have to pick up on the phone to make it stop ringing. I guess it's worth mentioning that I do have Unity setup but haven't got that part working.
Once again thanks for everything.
Problem solved, I got rid of the command ring number 4 from the voice port 1/0/0 and the calls started coming in, thanks for the help Shanky.
Bronze
I am using a call manager express with an FXO but using the 'connection plar opx xxxx' under the voice port.
Not sure if this will solve but may help.
voice-port 1/0/0
connection plar opx 29992
codec g711ulaw
More info on PLAR <http://www.cisco.com/en/US/partner/tech/tk1077/technologies_configuration_example09186a00800942a5.shtml>
Interested to see how you go..
133
