Hoot and Holler
I implemented hoot and holler in three sites connected through frame relay(hub and spoke). The spoke sites can hear the hub site but the hub can't hear both spokes, and it is happening intermitently. Any suggestions or experience with this type of problem? Below is basically my configuration on all the routers (Cisco3640 w/ NM-2V/2FXS)
Thank you very much,
Jimmy
ip multicast-routing
voice class permanent 1
signal timing oos timeout disabled
signal keepalive 65535
interface Vif1
ip address 10.100.30.1 255.255.255.0
ip pim sparse-dense-mode
interface Serial0/0
no ip address
encapsulation frame-relay
service-module t1 timeslots 1-4
frame-relay traffic-shaping
no frame-relay broadcast-queue
frame-relay ip rtp header-compression
interface Serial0/0.4 point-to-point
ip address 192.168.5.6 255.255.255.252
ip directed-broadcast
frame-relay interface-dlci 30
class hoot-n-holler64
router eigrp
network 10.0.0.0
network 192.168.5.0
voice-port 1/1/0
voice-class permanent 1
input gain -3
output attenuation -4
echo-cancel coverage 32
playout-delay nominal 150
timeouts call-disconnect infinity
connection trunk 111
dial-peer voice 1 voip
destination-pattern 111
session protocol multicast
session target ipv4:237.111.0.0:22222
ip qos dscp cs5 media
1 REPLY
Re: Hoot and Holler
Check your IOS on software bug toolkit. Intermittent problems are often bugs.
111
