Hotfix for Sql..
I'm having problems with the hotfix for the Sql SP1 and 2 load that Cicso says to install. When I follow the instructions and replace the files the Sql server will not start. What should I do?<br><br>
Gold
Re: Hotfix for Sql..
Hmmmm... I have put this on all of my test server without any problems. Did you drop all 3 of the files in the correct location? Do you get some sort of error message in the log? Did you already have SP1 or SP2 installed first? You do need the correct SP first.
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
Anonymous
N/A
I seems the machine I was running the hotfix on is very flakie... After rebooting and throwing the machine around a little the hotfix worked. Thanks for the time. Next time I'll try to get better machines.
Gold
Maybe this is part of your SP1 problem on the other post. I would try to head up to SP2 ASAP and install the SP2 patch.
Keith
Keith Chambers
Cisco Systems
87
