How can I build a VOIP SMALL LAB?
Thanks.....My budget is low.....
Super Bronze
Re: How can I build a VOIP SMALL LAB?
I'm guessing you mean for the CCIE lab? It really depends how comfortable you are with various parts of the exam blueprint..
You will need at least a few phones - I'd recommend you really need 7960s, and say three or four... hopefully you can borrow these as you don't often find them 'cheap'...
You'll also need a switch (doesn't need to be PoE if you have the power cubes for the phones), and ideally a couple of routers (one should be SRST capable, both should have some voice interfaces) to simulate a WAN...
You'll need a couple of servers - for this it's common to use VMWare (VMWare have a free product named VMWare Server which is great, use that)...search around for how to get CM running in a VM, the info is out there. Unity is simpler to get running (or at least the same as running on a real server).
You'll also need to run IPCC, I ran this co-located on the CM VM.
You get a version of IPCC Standard when you order the eval kit for CM4.0 (part no CM4.0-K9-NFR=), Unity demo kit is (UNITY4-DEMO-10USR).
Important things to concentrate on are the core products and all the features that are available; some of the more obscure hardware from the Lab Blueprint aren't easy to get hold of but are worth getting experience on - some companies out there have remote labs so maybe these are worth trying (it will be cheaper than spending $$$$ on a 6500 with a 6608 for example).
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron,
I am to interesting about it, so
Two questions,
1.- We can install CCM over 2 or 3 PC and use a router switch power in line ( spare ), and create a segment on 6500 to test mode.?
2.- Or instal CCM on just one MC and VM on PC for wan we use a segment from 6500, separate power in line switch?
Thank
201
