HOW DO I BLOCK OUTGOING CALLER ID ON A E1 (T1 ON US), ON A CISCO 3640
I WANT TO KNOW IF IT IS POSSIBLE TO BLOCK MY E1 CALLER ID ON THE CISCO 3640 ROUTER, FOR MY OUTGOING CALLS, I ALSO WANT TO KNOW IF IT IS POSSIBLE TO CHANGE THE DISPLAY NUMBER TO WHATEVER I WANT.
THANK YOU
FEDERICO LEON.
Re: HOW DO I BLOCK OUTGOING CALLER ID ON A E1 (T1 ON US), ON A C
Yes and Yes.
You can use translation patterns to change the caller ID just about any way you like, or you can use the answer-address command to change it to a fixed value
How?
thanks
173
