how do i register 2600 with FXS port with opengatekeeper
Hi all
i have 2600 with 2 fxs ports.
i would like to configure this 2600 router with my opengatekeeper
like fxs port 1 with number 5555
like fxs port2 with number 6666
iam able to register ATA 186 with opengatekeeper using 1111
and iam able to register netmeeting PC with 2222
iam able to call 1111 to 2222 and 2222 to 1111
not i want to configure to call 2222 to 5555 and 6666 and viseversa
but iam not able to get any sample configuration to configure with opengatekeeper
can any one send me the sample configuration for the same
thanks in advance
hari
can some one send me the sample configuration
Re: how do i register 2600 with FXS port with opengatekeeper
Let me make sure I understand your question correctly please.
What is an Opengatekeeper? Is it a 3rd party vendor equipment? If so, then we do not have information on them, we have information on the Cisco equipment. If you need help configuring your cisco 2600 gateway to register to the gatekeeper with E164 registration using numbers 5555 and 6666 then yes we can provide the gateway configuration for you.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t5/h323v2.htm#xtocid249097
(You need to use the register CLI under dial-peer config).
The rest of the gateway config is similar to config below:
http://www.cisco.com/warp/public/788/voip/voip_gw_gk.html
Hope this helps.
hi
thanks for your reply, sorry for the delay, i was out of town
the gatekeeper is GNU based, its running on redhat linux
iam able to register with Cisco ATA 186, and make call each other using 5 boxs
now i was i want to register this 2600 router with 2 fxs ports should talk to ATA 186 ports and the same from cisco ATA 186
thanks
153
