Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How do I start?
Hi guys,
Currently, I intend to try VoIP in a LAN environment. The tools/equipments I have here are only the Cisco IP communicator software phone and Cisco 3745 and 2811 routers.
Can you advise me on how to I start out? The objective is simple. Just to let the users in that LAN to do VoIP usig the softphones. Btw, is callmanager free to use if I have those Cisco routers?
Re: How do I start?
Hello Kengyiam,
You can use the call manager express software on the router to have call routing in place. this software license is not free. you might need to buy a CME license ---> FL-CCME-SMALL Cisco Call Manager Express Feat License For Up To 24 Users. This is a low cost license.
Once u have this license, you can configure the CME to switch calls between the IP comm PCs. refer to :
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_installation_and_configuration_guides_list.html
hope this helps.. all the best..
Raj
Re: How do I start?
Hmmmm... if that is the case, how do I check that CME license is already installed in my router? Im not too sure whether this router already has this license. THanks.
Re: How do I start?
What your really install is not the license, but a set of files that together make up the CallManager Express features. The license is a permission from Cisco to make use of those files.
Try a show flash, if you only have the IOS image file, then you don't have CME installed. After installing CME, several files and directories are copied to flash.
Go to http://cisco.com/kobayashi/sw-center/sw-voice.shtml
Then select CCME/SRST
After you have purchased the license, you can download the image file from this site and install it. For instructions on installing CCME refer to http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guides_list.html and http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_installation_guide_book09186a00805267ac.html
Best regards,
Rafael Campos
110
