how do you configure voice and data over frame-relay with separate dlci's
I have 2620 at the remote site with two pvc's. At the head end, I have a 7206 router connected to a 4006 switch with a rsp card with separate vlans. The Call Manager is on vlan 20. How do I configure the routers to have voice only on one pvc and data only on the other?
  • Other Collaboration Voice and Video Subjects
1 REPLY
Anonymous
N/A
Re: how do you configure voice and data over frame-relay with se
Since the call- manager would have to call signalling directly
over ip to the remote side, you'll have to use policy routing
to send voip traffic over one dlci and data over the other.
_ also make sure you have the right QOS on the frame-relay pvc's
_ you're doing fast switching for policy routed packets.
here is a sample config for input interface from call manager on the c7206.
int fastethernet 1/1/0
ip address 1.1.1.1 255.255.255.0
ip policy route-map traffic-warden
ip route-cache policy
int serial 2/1/0
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
int serial 2/1/0.1 point-to-point
ip address 2.2.2.1 255.255.255.252
frame-relay interface-dlci 100
class Voice
int serial 2/1/0.2 point-to-point
ip address 3.3.3.1 255.255.255.252
frame-relay interface-dlci 200
class data
access-list 101 permit tcp any any eq 1720
access-list 101 permit tcp any any eq 2000
access-list 101 permit udp any any range 16384 32726
route-map traffic-warden permit 10
match ip address 101
set ip next-hop 2.2.2.2 3.3.3.1
route-map traffic-warden permit 20
set ip next-hop 3.3.3.1 2.2.2.1
map-class frame-relay Voice
frame-relay CIR 64000
frame-relay bc 640
frame-relay fair-queue
frame-relay ip rtp priority 16384 16383 48
frame-relay fragement 80
no frame-relay adptive-shaping
map-class frame-relay data
frame-relay bc 640
the data map-class is setup similar to the voice because this would be a redundant link for
all traffic too if the voice pvc fails. the QOS as been put inplace just in case. Also the
data packet need to be fragmented regardless and data can use all bandwidth as long as no
voice flow throuhg the data pvc.
85
