How gateway registers with gatekeeper?
what is the command to be used on the gatekeeper to allow a VoIP gateway to register with the gate keeper?
in other words what mechanism tell gatekeeper allow gateways to register and how can one prevent unwanted gateways to register..
Anonymous
N/A
Re: How gateway registers with gatekeeper?
Intra domain security h235, refer to the following url:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t6/gwsecacc.htm
H.235 is the most secure. If you just want to limit based on source IP Address then just use the subnet command with 32 bit masks to define specific gateway IP addresses that may register in a zone
94
