Community Member
How many calls 3661 Voice gateway can handle? help
hi,
i have 3661 with E&M connecting the PBX,
if my PBX Supports 120 phones, it means the 3661
can handle 120 calls concurrently?
if i used 3661 with 6 NM-2V (12 VIC-2FXS),it can
handle 24 calls concurrently?
if i used AS5300 WITH 4E1(can support 120 calls ),connect to the PBX,if the PBX supports 200 calls, does it mean the AS5300 support 200 calls concurrently?
thank you
Community Member
Re: How many calls 3661 Voice gateway can handle? help
The gateway can support the number of possible voice channels, not necessarily the number of phones on the PBX. With 6 NM-2V, you can support 24 calls (since that is 4 calls/ports per NM-2V). The NM-2V will support E&M or FXS or FXO. With Digital ports on the 3661, you can support many more calls simultaneous since each T1/E1 will support 24/30 calls.
With the AS5300 you have 4 E1. This means 4X30 = 120 calls. If PBX supports 200 calls, you still are limited by the number of voice channels you can connect to the AS5300 which is 120.
Community Member
what's the Digital ports on the 3661, for example:
with 3661 i have NM-HDV-1E1-60=, the diagram i supposed is below:
(60)ip phone ----switch----3661(NM-HDV-1E1-60=)---WAN
or
60 phone---PBX---3661(NM-HDV-1E1-60=)----WAN,
which one is correct?
if the last one is correct, which cable for 3661 connecting PBX,
THANK YOU IN ADVANCE
212
