06-27-2002 09:30 AM - edited 03-12-2019 07:29 PM
I got two PVC from a host router ( access link is 56 K) going to 2 remote locations, each PVC is 16 K CIR.
How much bandwidth I need for each voice channel to be initiated from host location.
06-27-2002 09:30 AM
you need to use g729 and with VAD, header compression enabled.
one call will consume about 11-12k.
06-27-2002 10:24 AM
This depends, do you have VOFR or VOIP? If VOIP, then as other response says, 11-12k with vad and cRTP. VOFR is 10k/call for g729 and there is no cRTP for VOFR, vad can help to some extent. So for 56k, you can run up to 5 calls comfortably if you do traffic-shapign and prioritization correctly.
Hope this helps.
