how to adjust voice volume on voip ?
1 REPLY
Re: how to adjust voice volume on voip ?
you can change the input-gain on the voice port...you can change the input gain from
from -6 to 14 dB. The default is 0.
check this link for a detailed explanation..
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1839/products_command_reference_chapter09186a00800b3508.html#1045901
127
